Aluminum fittings any corrosion issues?
Hi All,
I'm interested in how well aluminum works for knife fittings (guard, possible handle scales etc) and specifically how much of an issue galvanic corrosion is. I see a fair amount of aluminum handles mostly on folders and a lot of those are anodized which would prevent much of the problem I assume. Many older knives seem to use aluminum pommels (without anodizing) and they seem to be fine.
Are there any specific tips/tricks or things you need to do or is this mostly a non issue?
I am planning on using 1095 and 5160 for some heavy copper type blades if the steel makes any difference.
Thanks
