D_R_Sharpening said:
Flame me if you will folks but I have to say this...
What the hell is Cliff talking about?
Seriously, I've read and re-read all that has been written and like usual I have no idea what he's saying. Is this just me or is he arguing to argue? Maybe I'm too stupid to understand or he's too smart to explain?
--Dave--
What is it, that you don't understand, and where is the argument here? I don't think that anybody has been arguing in this thread. Cliff gets occasionally in arguments, but I don't see one here?
Maybe I can translate: Cliff simply said that you have to pay attention to the burr and that the burr is not unique to coarse grit sharpening. Only that you usually see/feel it when sharpening with coarse grit more readily.
Later the discussion when to sharpness. Cliff says that sharpness is not dependent on angle or grit finish. What he refers to as "sharpness" is how well formed the edge is. However, cutting ability is highly dependent on the both on finish and edge angle/relief angle. Even if the edge is sharp (well formed) but thick, cutting ablity will be low (imagine using very sharp scissors using it like a knife). On the other hand, if the angle is low but even if the edge is not really well formed it may cut resonably well (example a SAK), Same if the edge is sharp (well formed) but coarse, pushcutting will be mediocre, but pull cutting will be good. He is also referring to the fact that you can get a very well cutting coarse edge, but that it is very difficult to get a well formed (sharp) edge with a coarse medium since the burr will form so readily.
Finally the discussion went on to primary and secondary burrs, terms that I have not encountered before, but Cliff has explained what he means. The primary burr is what you usually consider the common burr that you get from sharpening. According to Verhoeven it is consists of debris (metal carried to the edge or pushed away from the edge and abrasive welded to the edge). What he calls secondary burr is a deformed edge. First you form a sharp edge (well formed) but during use the edge deforms and bends over forming what looks like a burr but it's made up is good steel, not debris.
Cliff also mentioned early on, that burrs are easier to see, when they are bent one way or the other. If they are perfectly aligned with the edge, they are more difficult to detect (not sure if I agree with that).
All in a nutshell, of course.
Does that help? (Cliff, feel free to correct me if you feel I misrepresented what you said)
