The inside coils are really starting to take shape now. I'm using the needle files to cut the preliminary inside grooves (effectively drawing the line of the "staff" the snakes are coiling around down to the point of contact with the snakes), then using the Dremel to smooth out the snake body from the inside curve out.
One of the "crazy" ideas I can't quite seem to purge is to deviate from the standard caduceus design a bit in the area of the snake heads. On the picture the two heads are facing one another. I'm thinking about having one snake face out on each side of the blade instead, so the heads continue the line of the coil. That would also allow me to carve out two eyes for each snake, and the really crazy idea is to mount small gems in those eyes. I have a bunch of tiny gems... but my concern is that they'd just be glued in, and prone to popping out. The gems would really be ancillary to the design... the more significant thing would be the change of the head positioning.
I also spent some time yesterday thinning out the snake bodies so I'd have half a chance of putting a real edge along the outside curves. I probably removed 20% or more of the thickness, substantially flattening the sections that will have an edge. I was worried that might make it look flat and dull, but it really made it look smoother and more sinewy.
- Greg
