- Oct 17, 2007
I attempted to fix some kitchen-sink plumbing, and blew the top off. Water everywhere at 35 psi...splashing off of our high ceilings and landing on my lazyboy in the living room 20 ft away. Not finding any shut-off inside, I ran out to the front of the house and started digging down into the dirt and sand to where my Main shutoff valve is located inside of a large vertical iron pipe, with a cast iron lid on it to keep out the dirt and sand. Of course I dug with what I had...my Umnumzaan. And when I got down far enough and struck the pipe, I had to jam the blade into the finger-hole in the six-inch-diameter cast-iron lid in order to lift it off of the pipe. Once that was done, I reached down into the pipe, scraped away excess sand and dirt and turned off the water MAIN. Yes, I fixed the sink later.
The S30V blade on my Umnumzaan suffered a few minute chips in the cutting edge, which I should be able to polish out quite readily. The knife performed admirably; well beyond the requirements of "casual carry." In this case, it served as an entrenching tool, a pry-bar and a metal scraper. The rather "soft" heat-treat of 58-59 BRH allowed the blade to be stressed, torqued, pried and twisted, without any serious damage. I never did cut with it that day...
So that, sir, is "abuse" of an expensive folder built with extreme precision by Chris Reeve. Hopefully, that is the one time that it will have to go through abuse of that sort. OTOH, a good product should be able to perform, when needed, beyond ordinary expectations, at least for a short period of time before suffering unrecoverable failure, and this Umnumzaan certainly "proved that it's worth every penny.
It is still my EDC; I expect no rapid changes of "the Guard."
You don't have hot/cold shut off valves under your sink?
