Amount of oversize for pivot head?
I have been looking around and didn't really see this covered explicitly, or if it was I missed it.
I am using Alpha Knife Supply 3/16" pivots. The heads are 0.29" diameter. This means that I can use a 19/64" (0.296875) or 5/16" (0.3125) counterbore for my recesses for the head.
I don't want to purchase tools that I am not going to use so I figured I would ask. Which size should work the best?
Does this change if I wanted to make pivot collars?
If you guys have pics of your AKS 3/16" pivots in your holes could you show them to me and let me know what counterbore size you guys use. I will probably end up using an end mill bit to do the counterboring.
-Brian-
If you're using a drill press instead of a mill, also look at removable piloted counterbores.
They ensure that you are lined up on the hole center
Yeah, that crosses my mind. I saw a set up with a plate of g10 and pins that was suppose to help with the lining up. But it might not work out
But I need to calculate the price. Which ever way is cheaper.
If I'm making a frame lock, I use a 9/32" bit and follow it with a modified size "L" reamer to get a light press fit for the head of a 3/16 AKS pivot on the frame side. It's pictured in the first page of my WIP here:
http://www.bladeforums.com/forums/showthread.php/916004-Virtual-BBQ-WIP-GNiCr40Al4-frame-lock-folder
If you use that method on the screw side, a little material can be removed from the side of the screw head to get clearance as shown in the WIP if you don't have a 19/64" bit.
you can see how the method of locating the pivot hole in the bolster could be used on a liner lock as well.
If all you need is a clearance hole for the pivot head, a 19/64" bit would work best for a non bolster knife. If hidden under bolsters it could even be a 5/16" end mill. It doesn't matter that much in that case, unless being larger it begins to interfere with another feature such as bolster mounting screws.
Good stuff, thanks!
^ good advice
Generally you will use a press fit or slip fit for the pivot head... I use loose slip fit at .002' over because the tooling is easy to find (.312" pivot head into 8mm/.314" counterbore done with endmill)
I press fit the shaft (.249" hole with .25" pivot shaft). The AKS pivots have a "collar" made just for this purpose.
Also consider modding the pivot by turning it down, I just use my grinder and a hand held drill. They are easy to grind and only take a few seconds to turn down to size.
