Not knowing anything about your mechanical and shop skills, it is hard to suggest something, but here are some ideas and advise.
Don't get G-10 handles for any kits - they have problems that you are not ready to deal with yet.
Don't be too intimidated by skill levels, but the higher the skill level, the more equipment and experience it usually requires.
When starting,
use kits that have screws. This is the best place to start.
Some suggestions would be :
The 605 and 605 mini (605-M). Great kits and easy to build. (Jantz, K&G,etc.)
The GX6 - great look and an easy build. (knifekits and others)
The DDR-BL3 - hefty and a tough worker. Can be converted to auto by adding a $4 coil spring. (Knifekits)
Check out the many great kits and supplies at Darren Ralph's site - KNIFE KITS
http://www.knifekits.com/vcom/index.php
I make a lot of highly embellished knife kits and they sell well. I
can make the liners and blade blanks myself (and do when i need to) but when the finished product is mostly due to the work done in handles, modification, and filework....a kit provides a great foundation, and saves time. I sometimes use a GX6 frame and make a mosaic damascus blade for it, mokume bolsters, MOP scales, diamonds or gemstones, etc. It ends up being 80% custom with kit knife liners.
Take your time. Have fun. Be proud of what you accomplished.
Get a good set of torx drivers from a knife supplier(about $10).
Handles are where most of a kit's work is. Start simple and work up to hard.
GO SLOW Rome ( or a kit knife) wasn't built in a day....but a kit can be ruined in only seconds by trying to force parts,or speed up a slow task (like hand sanding).
Peening rivets is where there are problems for newer kit makers.This is why screws are easier to deal with. Plus, with screws you can take apart the knife or remove the scales as needed while building it. I would recommend an extra screw kit ( usually about $5-7 when you order the kit) on the first one. Screws get lost, cross threaded, or the threads get loose by continued in-out assembly.
Wood scales are easy to start with. Jigged bone is a good starter ,too ( easy to hide mistakes when it already is full of gouges). Drilling the holes and fitting the scales to the bolster are the trick. There are two ways to approach this.
One is to drill the holes in the scale material and then trim the scale to fit the liner and bolsters. Some find this the easier way. Others trim the scale to fit the bolsters,carefully mark the holes , and drill them last. This is what I do. A dremmel or similar tool is very useful in kit knife construction. variable speed is a real plus on these tools.
Have fun and email me if you run into a problem.
And....Welcome to the forums.
Stacy
