- Aug 24, 2016
How would the "lower tier" steels (420j2, 420hc, Aus8) of today perform against the "top tier" steels of the 19th century?
18th Century?
18th Century?
Maybe certain, highly specialized steels but there is such endless variety of steel now, with such specific properties, and such deep knowledge of metallurgy, that I have no doubt that we could produce the most badass-performing sword of all time if we really wanted too. Meanwhile, the best steel from a hundred years ago would come apart like peach cobbler if we tried to use it in some of the applications for which we use steel now.To ask if modern entry tier steels is better than historical steel is a tricky question. There are modern steels so hard that they may have been too brittle for a sword from 1789. In this case the historical steel was clearly better suited for its role in a sword.
A good heat treat for the steel type is kind of magical. It's kind of like the magically infused swords that I read about in fantasy novels...... that I have no doubt that we could produce the most badass-performing sword of all time if we really wanted too. Meanwhile, the best steel from a hundred years ago would come apart like peach cobbler if we tried to use it in some of the applications for which we use steel now.
AgreedA good heat treat for the steel type is kind of magical. It's kind of like the magically infused swords that I read about in fantasy novels.
I have little doubt that even the steels that we consider fairly low quality would be better than the steels produced a century ago. I believe in swords, damascas steels were used simply because they worked better for the rigor that a sword might get used for.
DisagreeMost users probably wouldn't even know the difference, lmao. By the way, us forumites are not "most users."
Personally, I think that the difference would certainly come out over time. Maybe that 19th century guy wouldn't notice the difference the first time he swung the sword but he'd notice it by the thousandth.
Consider high quality Japanese Swords by the Masters from the 17th and 18th centuries. I believe those blades perform as well as anything made today.
18th Century?
Go back far enough you'll find early swords were iron, not steel. I will even say that the first damascas steel was not good steel it was just better than iron.
