alexmin said:
Guys,
since you talking about marquench...
How do I learn to recognize that my O1 blade is about 350 F and I should remove it from oil to cool in still air?
Thanks,
Alex
Shoot for 400F-425F, just above Ms (martensite start) is best. The oil can tell you a bit, since most oils have vapor points arouns this range, if you pull the blade out and it has a light coating of oil that is giving off some smoke, it should be pretty good. If the oil quickly evaporates, and it really smokes a lot you are probably on the high side.
Do some practice runs. Get some thin stock of the steel you want to use and quench it, put gloves on before hand, then count off as you quench. Interrupt and grab the steel with your gloved hands and see how easy it is to move. If you are above Ms the steel will bend very easily and you will then notice that as it cools the steel will get progressively stiffer.
Anther tool to practice with is our old friend the magnet. If we have completely nailed the quench down to Ms, the magnet will not stick to it until enough martensite has transformed for it to do so.
Of course there is the old "ouch" test that so many get talked into trying at least once, to the endless amusement of others
, if you touch the blade with bare fingers and you end up with scorched skin and blisters- IT WAS TOO HOT! If you can easily grab it with little discomfort- it was too cold. If you touch and it instantly makes you wnat to say "OUCH!" but that is the extent of it- it was probably about right
, but I recommend some of the other methods to practice
