- Dec 7, 2008
Ancient Bog Oak from Ukraine.
These are priced $45-$65. Good dark coloring and nice grain patterns. These blocks were cut from a log that was salvaged in an area where another tree was carbon dated to be 2800+ years old. Meaning that almost 3000 years ago these trees were washed away and became buried in the sediment. During that time the buried logs absorbed minerals from the sediment giving the dark coloring and a nice luster to the wood. The carbon dating certificate was the result of the testing done on a sample from one of the other logs. While the date is not exact it gives an estimate of the age of this wood. This is untreated wood. It has not been stabilized (chemically impregnated).
These blocks were left unstabilized so they can be used for projects that will involve carving, texturing or where a lighter weight material is desired in comparison to stabilized blocks.
For hard use knives I suggest waiting for the next batch of stabilized bog oak that should be arriving in about a week.
The Walnut blocks are extra thick blocks (about 2inch) average price $30.
These blocks were cut from the crotch section of an Eastern Black Walnut where the figure sometimes forms a feather. Hence the name "crotch feathers. The wood is noticeably harder than the west coast Walnuts. Very good coloring with an orange-ish tint. Good crotch figure that changes when the light hits from different angles. Eastern Black Walnut is a very durable wood that is suitable for use as handle material, even on heavy use knives. I prefer using a Danish Oil finish for the best results. This is untreated wood. It has not been stabilized (chemically impregnated).
I had not intended to offer more unstabilized walnut blocks, but the others sold out and there were requests for more.
Click on a photo if you would like to go to the store for a closer look.
or Use this link if you would like to go to the store for a look at all the new pieces.
Get a 10% discount by using the coupon code forum.
Before checking out be sure to click the link that says view or edit your cart. This is where you can review what has been added to your cart and see how much money you are spending. Toward the bottom of the page you will see a field for a coupon code. Enter the lower case letters forum and then click the GO button. Doing this will apply an additional 10% discount to your order which will be shown in your shopping cart. Now you are ready to check out.
If your order is over $200 after any discounts, the store software will automatically apply another 10% volume discount to your order.
Just a warning:
If more than one person are attempting to buy the same piece the store software will give it to whoever completes check out first. So it is best to add your selections to the shopping cart and check out promptly.
Just a warning:
