It could possibly be a hole to put a safety pin in.
Andrew said it's there to match the fixed blade version.
Yeah thats what I read too. It could allow a pin to stop the blade from rotating as CM said although the blade would be allowed to travel some before hitting the pin. Still, it could be an effective back up for the lock if you just knew in advance you were going to beat the snot out of it. I've actually thought to do that on some I've tested planning to spine whack the crap out of or overstrike hard and of course just to protect my fingers in the event of the unforeseen.![]()
STR
Steve I'm curious as to why you wanted such thick liners on yours? Andrew actually recommends no liners at all but people seem obsessed with heavy duty liners..... I just wonder why.
I wanted the knife for the end times. The knife for Armageddon so to speak. You know, something that would be a no compromise no holds barred go getter and thats what I got. I don't regret it either.To me the difference in weight between the full lined vs the all G10 was only 1 ounce plus or minus a few tenths and at this point it was like, thats not enough to worry over. My next one from Andrew will be thinner more geared for EDC but this one was one I wanted to be very special. Besides that big as this one is its not really any bigger feeling in the pocket than a ZT 0200 or 301-302. Actually I can still get my hand in my pocket to get my keys with this knife. I was having to take the 301 out first to get my hand in there so in that way its still better. It only weights 2 tenths of an ounce more than the 301 I owned also.
STR
Well in that respect, it certainly qualifies. Although the liners on mine are only half as thick as yours I'm quite keen to try a linerless one myself... when I get round to that I suspect Andrew will say: I told you so.![]()
I figure if they can hang 400lbs off the regular AL which is linerless I'm not really going to lose anything in the bargain.... except a little weight that is. Which in summer around here can mean the difference between carrying it and not carrying it....![]()
I thought they hung 250 pounds of the AL not 400? Still 250 is quite a bit for a folder of this size.
STR
STR
Heck, I may just get a Cold Steel one. I have no problem with AUS-8.
