Angle for blade sharpening
whats up i work in an abattoir (slaughterhouse to most people) and was wondering what your thoughts were on the best angle to sharpen your knife on. i use a fixed sharpener and porous stone and use a 25 degree angle. alot of the guys at work use 20 but i think the edge comes off to quickly when its too fine.
Welcome!
Greetings to Oz.
I often use 15° on my pocket knife blades, but sometimes 20°.
I always use 20° on my kitchen knives.
(It should be noted that a lot of folks here think 15° is too thick.)
What's the angle on the Lansky? Is it per side or inclusive? Are we talking per side or inclusive?
What are you cutting?
How big is your blade?
What type of steel?
What grit are you finishing your edge at?
What type of steel?
:thumbup: Agree! These are all questions that should be considered when sharpening your knives. The wrong angle on an edge can make the job you're using the knife for a whole lot harder...okay maybe not a whole lot but the difference would be noticeable.
Splitta, if ya boning out beef, I'd be working on a 20 per side. It will make the job a bit easier than working with 25.
At 20, the edge will roll alot quicker if you keep hitting bone, but just give it a few strokes on your steel to bring it back to life. If your blade is chipping at 20, or 25 for that matter, you have a crook blade.
Is the company providing you with knives or do you provide your own? What brand are you using?
As mentioned above, you can prolong the need for sharpening by keeping that edge aligned on a smooth steel.
