- Oct 19, 2005
Just got one. Are there jigs I should build? How do you secure it to a table to use as a profile grinding tool?? Safety concerns?
I clamp the blade steel down in vise grips and a table vise and hold the grinder in my hands. Still use a respirator and face shield and goggles. I've found that while gloves will keep my hands clean that they can catch on the disk- long close fitting sleeves will keep the sparks off your skin.
i find that when your making a vertical cut and have the angle grinder turned sideways and are cutting from top to bottom, be sure to turn it so the motor is on the left and the disk is on the right. this way the sparks dont fly towards you but away from you. if your do the same cut but are going straight into it with the grinder, then turn it the opposite way so the sparks fly downwards. i find wearing a long sleeve shirt with the gloves helps out too. you wont get little sparks flying onto your arm. hope that helps out.
