- Feb 17, 2009
While I respect and sympathize for those that have been injured, I have worked with angle grinders in both an industrial setting and at home(which is now my workplace) for almost 3 decades.
I don't quite understand how angle grinders are these "dangerous, don't belong in a knife shop" monsters waiting to burst one of your nads. Use it correctly, wear the gear. I've had many cut-off wheels come apart without injuries. What you need to realize is that these aren't heatguns, dremels or hand drills. They should be treated with as much respect as a 2x72 grinder, drill press, lathe or welding unit. Their size and portability must be what is letting folks put their guard down.
Get a good model with an adjustable "second" grip handle, use the guard(most are adjustable, too) clamp your work down and always be mindful that what you are trying to accomplish is on the agreeable side of physics. I will often run the entire cut in my head before the real thing... and have changed my approach because of potential issues.
But would you feel the same if the cut off wheel came apart and killed you ?
