Annealing 15n20
Hello, Bladesmiths;
I have a small kiridashi that I just heat treated and am now annealing at 425, twice, for 60 minutes. It's 15n20 at .096. Does that sound about right?
Thanks,
Sprayman
Hello, Bladesmiths;
Thanks,
Sprayman
You mind you tempering 15n20 , right ? 15n20 is very tough steel , for knife I temper them on 360 and my parang machete I temper on 400 and they hold pretty good .Anyway wait for advice from more experienced maker ;)
Hello, Bladesmiths;
Thanks,
Sprayman
We use the term tempering instead of annealing. I think 325-350f would be good for this kind of knife. Maybe JT will chime in on this.
Hoss
Just doing in my forge I think I also got 61 to 62. I tested several pieces and can't remember if the top of my head. It is very easy to work with.
Speaking of annealing 15n20, I got mine from Alpha Knife and it comes a little harder than I am used to. I killed some drill bits the last time I used the bar. I read here about heating it up and then letting it slow cool in some Ash to soften it up for easier machining.
Is that correct? Can I heat it an let it dry in the air, or will that cool too fast?
Just get some coblat bits in the sizes you use. Run them slowish.
