I notice most guys who heat treat carbon steels like to normalize at least 3 times prior to quench.
Correct me if I am wrong ... to normalize, you heat to non-magnetic, hold for a few seconds and then let it air cool, right?
What if you let it cool in vermiculite instead? In effect this is annealing, right? Would this also remove stresses and result in smaller grain size due to the slower cooling rate?
Has anyone annealed or triple annealed a blade prior to quench? Would it be better than normalizing or is it a waste of time?
Any insight would be really appreciated! Thanks! :thumbup:
Air cooling is a great happy medium between annealing and quenching. You see if you quench from proper normalizing temperatures you run the risk of cracking many steels, while cooling too slowly will not give the uniform refinement you are looking for. The TTT curve and the Iron -Carbon phase diagram are both based upon Equilibrium conditions, that is things are held at temp long enough for those structures to form. Equilibrium is not necessarily what you want in heat treating that involves cooling as it allows thing to happen that you dont want to happen.
If you are dealing with a steel that has over .8% carbon allowing equilibrium conditions above the pearlite phase will cause separation of carbide, and if you give it time it will go right for the grain boundaries. Course pearlite will form as it drops more. Yes you will have a very stress free soft blade but that is not the goal of normalizing. The goal is to homogenize and refine the inside of the steel. Industry recommends that you not normalize L6 because that will only harden it, but I still do for the sole purpose of refining structures, I just need to be more careful.
In general the quicker you cool steel the finer the products will be, the slower you cool the coarser they will be. Use heat to mix it all up and then cooling to refine it where it is, gong really slow will set you back to square one. And lets not forget the best reason to air cool- getting back at it sometime today
The most common questions asked in this business begin with what if you
What if you quench in
, What if you used
What if you heated
, all very good questions if you are looking to improve upon something some bladesmith is doing or advising, but it can get you into problems if it concerns something that the folks that made the steel suggest, as they pretty much have figured the whole thing out quite well, in the most effective and efficient way. As bladesmiths, for the time being, we need to always be looking for ways to improve how we do things, for this all we have to do is look to industry and trust that they know what they are doing. I have found that many of the numbers in those books dont work as long as I try to mix the goofy bladesmithing ideas with the industry standards, but as soon as I just let go and trust the folks who made the steel and put the bladesmithing concepts aside for a minute, all the numbers start working just like they do in the books. Reinventing the wheel can be quite exhausting if you need to do it every day.
