Annealing question
Hi, Newbie here,
I have a damascus blank that I bought. Tried to put one more hole in it so I can put a cord on the handle, but of course only got a bit beyond a dent in the metal before my bit started screaming and failed.
I have tried to run a search here but get a bad message so I am either prohibited from searching (maybe a newbie thing) or it isn't working.
So how do I anneal this? Take a torch, heat area to red hot and let cool? Does that affect the rest of the knife?
Thanks
Randy
You can use a carbide tipped drill bit to cut through hardened steel. You can't truly anneal just the handle, although you could soften it with a torch.
Yes, I want to soften it enough to drill the rest of the way through. I have to go to town later, so maybe I will pick up a carbide tipped drill bit. It's so hard to wait though!
The search engine you suggested was what I needed Stacy. Thanks.
I heated the end of the handle to a dark red and let it cool slowly. Then used a masonry bit I had (got that idea through my search) and it was easy to drill through.
I hope you were holding the edge in a bucket of water, otherwise you probably messed up the temper by overheating.
Wrapped a wet tshirt around the blade and then held that with a teflon oven mitt while I heated the end of the handle with a propane torch...how do I know if it worked or not?
