Annealing ?'s
I grabbed some mower blades to try and learn how to grind and shape, without beating up alot of more expensive steel. First thought they were 1085, and was positive I read somewhere that they could be annealed in a kitchen oven. I heated and held at 450 f for 2 hours, then cooled and held at 200 for 2 hours, then slow cooled to room temp. They cut like a bugger!!! The Junk yard steels charts I have read said they might be 5160. Am I way off base with temps and times, or is the "best" hacksaw blades at Home Depot just not the right tool for the job?
For annealing, you need to exceed critical,
which is 1400f +.
At 450, you just gave it another temper,
probably didn't soften it much at all.
Try a search for "annealing" or "spherodizing".
Both have been discussed here, at length.
which is 1400f +.
Yep, consulted my notes, evidently I need to keep them better orginized. Thanks for the advice.
Good evening Mich.
For what you'll spend on equipment to anneal these cheap blades of unknown steel, you can easily get 50lbs. of annealed 1084 from Aldo.
http://www.bladeforums.com/forums/showthread.php?t=575167
Use a bar or two to learn on, then spend the money on a proper heat treat oven when the time comes.
Just my opinion, but if I can help out in anyway, don't hesitate to ask -Cliff
They are , according to someone who worked in the industry, a 15xx steel .I don't remember the carbon content. Very simple, nothing fancy.
:foot: I wuz going by memory, evidently that aint so good. Transposed temps.
Thanks for setting me straight.
Matt
