- Apr 29, 2013
I am hoping that you got the terms mixed up, Stacy... or I am off on my info. Normalization(not stress relieving) is usually done after forging.Annealing is pretty simple for basic carbon steels, but most other steels have more complex annealing requirements. Steel usually comes annealed.
Stress relief is usually done post forging, but some do it after heavy grinding. It releases any built up stress in the steel, but does not greatly change the structure or grain size.
Normalizing is done pre-HT to get the steel and its grain structure ready for hardening. Again, that is more important if the steel was forged.
Something else, if you don't mind(and I'm not drifting too much)...I run stress relief along with normalizing cycles after forging or shaping and bending. Its one of the set programs on my electric kiln. For something like 01 its one hour at 1200 ramp to 1600, hold ten minutes, cool to black, ramp to 1550, cool to black, ramp to 1500 cool to black. The hoped for result is steel with little stress and a very refined grain structure.
They didn't give a reason; just try this and see; so when it worked I was thrilled and have done it ever since. Two and a half years with no broken ones so it has a track record. Keep in mind I have my big Fisher anvil aligned with the earths magnetic poles; what does that say about me.Fred, Spring has just begun around here. :thumbup:
I think you normalize after working/tooling, just before HT?... I don't. After forging, I normalize 3 times, quench, then spheroidize from 1250F. The grain is refined and in its softest state. I shape, drill, etc... and perform a 1200F stress relief cycle prior to final HT. I still can't think of the metallurgical reasoning behind SR after forging if you intend to thermal cycle before quenching, anyway.
I think your clamps are a different story, Fred. You drill, tap and grind them prior to the bend... so it is safe to say that the most stressful state is after the bend, just prior to HT. I would definitely normalize before the quench. What was your process prior to talking to the mill? What metallurgical reason did the mill give you?
If I straighten after forging and grind properly, I should be inducing very little stress prior to HT. The SR cycle is just added insurance.
That is because you are closer to the north pole. It won't work in the lower latitudes. BTW, did you have to learn Gaelic to move to NS.
