Sorry, it's a PDF, you might not have a viewer installed. You should probably grab Foxit PDF Viewer or Adobe Acrobat Viewer to read the entire document, but this is copied from the document:
Thermal Treatments
Surface Treatments
Note: Properties shown throughout this data sheet are typical values.
Normal variations in chemistry, size and heat treat conditions may cause
deviations from these values.
DS 07/10 CPM 154 CM Crucible Industries LLC Printed in U.S.A.
Annealing:Heat to 1650°F (900°C), hold 2 hrs., slow
cool no faster than 25°F (15°C) per hour to 1200°F
(650°C), then furnace cool or cool in still air to room
temperature. Crucible 154 CM can be cycle annealed by
heating to 1600°F (900°C). hold 2 hrs., cool to 1300°F
(704°C), hold 4 hrs., then air cool.
Annealed Hardness: About BHN 235
Stress Relieving
Annealed Parts: Heat to 1100-1300°F (595-705°C), hold 2
hours, then furnace cool or cool in still air.
Hardened Parts: Heat to 25-50°F (15-30°C) below the
original tempering temperature, hold 2 hours, then furnace
Hardening
Preheat: Heat to 1400°F (760°C) Equalize.
Austenitize: 1900-2000°F (1037-1093°C), hold time at
temperature 30-60 minutes.
Quench: Oil or positive pressure (4 bar minimum) to below
125°F (50°C), or salt quench to about 1000°F (540°C),
then air cool to below 125°F (50°C). Salt bath treatment, if
practical, will ensure the maximum attainable toughness for
a given hardening treatment.
Temper: Twice at 400-1200°F (204-650°C), 2 hours
minimum each time.
Note: As with all martensitic stainless steels, tempering at
800-1100°F (425-600°C) will result in sensitization which
causes a minor reduction in both corrosion resistance and
toughness. We recommend that this tempering range be
avoided.
Aim hardness:HRC 55-62
typical values. Normal variations in chemistry, size and
heat treat conditions may cause deviations from these
values. For additional data or metallurgical engineering
assistance, consult
