I have one of these: http://www.circuitspecialists.com/prod.itml/icOid/7859
It's a DC power supply that isn't all bad for annodizing - I think.
I just had my first go at annodizing Ti last night. The results were underwhelming.
I could get a color once but not the same color twice. It turned into dunk it, pull it out and look and repeat - hoping you didn't 'go past' your color.
This little power supply max's at 1 amp over 30 volts - which isn't bad cause I can tell you 1/2amp at 50volts gets your attention! Problem is if I dip a piece into the solution, the amps max out at 1amp and the volts won't go much higher than 20v unless I 'tease' it by pulling the thing in/out or barely having the 'annode' item (another piece of Ti
I'm looking for any tips, help, suggestions, etc on annodizing Ti.
Is there a better commercial product for this?
I went to bigger pail of solution and that seemed to help me get the volts up but that still get me what I needed.
I ground off the surface oxidation and that made a big improvement.
What do you use for the annode?
Does how you hook up positive/negative leads matter?
How much TSP is enough?
Anyone have volts/color chart?
Any other tips?
Any other tips?
