Anodizer - Which Variac should I get
Thank you for viewing my thread. I need some help please.
Please help me locate an ideal variac for building an anodizer. I don't know enough about electronics to make a selection. I'm finding Variacs for sale but they either don't meet my requirements or they have very high prices. I've been wanting to build an anodizer for a long time but I just can't figure out which Variac to get.
From the instruction I have read, it seems that I am looking for a 0-140V, 5AMP variac. I want to have the 140V range so that I can get all of the high voltage anodized-colors. I have heard that there is a bright green color you can get around 130V and I want my anodizer to be capable of getting that color. Also from what I understand a higher Amperage Variac will be more dangerous to use than a lower Ameperage unit, so I don't really want to go above the recommended 5AMPs if possible. Also the instructions make it sound as if I will be able to find a variac that matches the description for around $50 on eBay. But I can't find them. If I can get a low price like $50, great. If not, I'll spend more.
Thank you.
Thank you for the link Mr. Boone. I plan to use Bob Warner's instructions which are very similar. I think I have a pretty good understanding of the construction. I just need help finding the ideal Variac at a good price. The ones I am finding right now are around $200+
I have got a couple from Fleabay for $30-40. Let me know if you need a source for high amp bridge rectifiers.
I got mine on eBay. Take a look, there are lots of them listed there.
Thanks for participating in the discussion.
What are the specifications on the Variac that you bought and how is it performing for you?
I have been looking on eBay but I don't think I am finiding the right Variacs. I found many 0-130V variacs but all of the 0-140V variacs are rated at 10AMPs or more. Should I just go ahead and buy a unit with higher amperage?
I have heard that some of the 0-130V variacs can not produce 130V even though it is marked on the dial. That why I have been holding out to find a 0-140V 5 AMP.
Yes, please refer me to a place to buy a bridge rectifier. Thanks :)
It sounds like you have experience with this type of thing. Do you think I should hold out for a 140V 5AMP variac or can I get something else? I don't know any better.
I got mine from Circuit Specialists. Its a fine DC power unit even if it is made in China. All I know is that it does a great job from 0 volts to in excess of 110 volts. I've used it for years. I think I paid $99 when I bought it. I hear its a bit higher now, seems like $129 but its a good machine. They sell several DC power supplies and I imagine they are all good but the one I can speak for personally is the CSI12001X.
This is all you need to do a great job anodizing your titanium. You can buy this from other places but this price was hard to beat and they shipped it right out. I was using it the day it arrived and its seen nearly daily use since. I was first turned onto these in the lab of a school I sub teach at from time to time. Its a durable machine be beat up by highschoolers. That alone sold me. The ones at the school have dents, chips, missing dials, you name it but they still work. :thumbup:
www.circuitspecialists.com
STR
STR,
Thanks for the link. Those are the Variacs I am finding on eBay and they are very reasonably priced. I could certainly a good seletion of colors from 0-110V. It's just that the instructions say that there are reasonably priced units that will do 0-140V at 5AMPS. I want the capability to go over 130V if I can get it. I am finding 0-140V 5AMP units but they are very expensive.
I want to find the $50 0-140V 5AMP Variacs that I have heard about, if possible.
Wish I could help you there but I only know the one I have. You may ask Circuit Specialists what is in the catalog if any that are not on the web site. I have seen bigger units in it when I had it. I've never cranked mine up all the way to see what it goes to but I have had it to 110V twice so I know it goes that high and above it.
I rarely find much need for most of the anodizing I do to go above 70 volts personally. Most of the color requests I get fall in that range.
Good luck on your search. If you find something good post it for us. :thumbup:
STR
You are misunderstanding the amperage rating of the unit. It is the maximum amount of current the unit can handle before failing, not the amount delivered. A 10 amp unit is better than a 5 amp one. The current delivered depends on the resistive load and the voltage applied.
Also - 5 amps can kill you at 120-140 volts just as surely as 10 amps. have a proper size fuse in the anodizer circuit, and if you are really worried about getting shocked, use a GFI receptacle to plug the anodizer into.
Stacy
Even if you aren't worried about getting shocked, use a GFI.
They sell them at the Depot, Lowes, etc.. for like $10 that plug into a non GFI, so you get GFI wherever you need it.
Like Stacy said, the bigger, the better.
Buy the best you can afford.
Mine's a 5amp model, and it's a champ.
I've been anodizing for 15 years with my old DC arc welder as a power source. Not the best choice but gets the colors I want and works.
I have an isolation transformer in my anodizer before it gets to the variac as well as a fuse. It will immediately blow a fuse any time the anode directly touches the cathode. The people making these were pretty emphatic to include both of these for safety.
I have a separate circuit with some huge high power resistors in there to be able to slow down the process if I want to, but I find that I never use them. I also find that my colors top out a little above 100 volts, and the teal green starts getting muddy looking and starts to turn somewhat gray above that due to several colors interfering at the same time. I don't always use MultiEtch, but the higher voltage colors tend to be brighter when you use it. I have a small Crock Pot to heat up the acid. I use a digital voltmeter to gauge the voltage. I just anodize rings, so I use a stainless cup with the trisodium phosphate solution and hang a ring on a hook connected to an alligator clip. the setup works very well for me.
Thank you for informing me about amperage Stacy. That pretty much settles it for me. I need to buy a higher amperage variac.
I have been reading everyones posts and checking out all of the excellent links you guys are providing me with. I'll have more to say in this thread after I have a chance to think about all the new information. Thank you all very much for helping me out.
I sent a message to Circuit Specialists asking about their DC power supplies last night
The Multi Etch is made from ammonium persulfate and sodium fluoride. It comes in a powder in the bottom of a 1 gallon jug that you add water to. It works best when heated, so a crock pot or other heater is used to heat it up.
Bruce
From what i read on Reactive metal studios - they wont ship outside USA -
any leads on canadian - international - the origional wholesale supplier ???
