Anodizing Titanium
Hey guys. I am looking to anodize my Benchmade 42 handles and I was wondering what the best way to do it is. I got a quote for $120 to send it out to a place in PA but id like to do it myself if possible.
My main question is that Im not really sure if I trust myself to do it well. Do you guys have any tips or should I just go ahead and send the handles out.
Any advice is appreciated!
for 120$ you can give it a try yourself.
You can redo it again and again for a different color every day
the color is based upon the voltage, I've been told a fresh 9 volt battery gives a nice blue.
( you could also scan the junk shops for electronics plug packs - )
I'm not going to type the whole procedure here see reactive metal studios for more info
-cleanliness is key
http://mrtitanium.com/anodizing.html
The best way to do something is the right way. :)
What equipent are you going to be using to do the anodizing?
if the answer is 'i don't know' then I would highly recommend watching Bob Warners video on building an etcher, plater & anodizer.
I think it may be called "the electrolysis of metalworking"
After you do your research and look at some tutorials you can make an anodizer for $50 for the Variac, a couple bucks for the bridge rectifier, and the cost of a mason jar, plastic canvas liner to keep things seperated, alligator clips, primary wire, scrap Ti for the other electrode that is not holding the work, and diet coke. Although some others use a soap type blend. Lemme cut and paste the info I have saved. The Howell tutorial is a good one.
Anodizing Ti
Do to complicated molecular reasons, anodised titanium goes a pretty colour. This colour varies with the voltage used. This ranges from gold for about twenty volts, via purple and pink at about 100 volts.
All you do is make up some electrolyte solution. I use sugar soap, 10 grams per litre. This is bought from the DIY store for cleaning paintwork prior to repainting to get the grease off.
Find a suitable power supply - use a PC power supply or whatever transfers you've got laying about with a rectifier to make up anything between 20 and 100 volts DC. If you are very clever, you can make a variable voltage supply. The exact colour you get depends on several factors, so experiment :)
See the image for an example of a bit of anodised titanium rod.
Simply attach +volts to the titanium part, and use a lump of lead sheet submerged into the solution for the cathode. Clean up your titanium to make it clean of finger grease and dip it in to the solution. After a few moments of fizzing it will take on its final colour. That's it!
Anodizing Al and Ti
http://astro.neutral.org/anodise5.shtml
http://www.howellbladesmith.com/index.php?BODY=anodize_titanium
Variac transformer
http://www.mpja.com/prodinfo.asp?number=15162+TR
