an old trick to check for proper recoil spring (most of the younger guys shooting .40SW in a single stack shoot very light springs<10#)... load one round in magazine, shoot weak hand.... limp wrist, ejected brass should clear port about 6inches...and slide should lock back (if you want it to)...change spring rates up or down to accomplish this (remember that cocking the hammer (main spring) affects recoil rate.... I ran extremely high spring rates in a .45.... 22-24# ISMI springs that take a set to a couple pounds less....never had a problem chambering a .45 with high rates.... if you ever decide to pull it apart, check a parts diagram, there is a small spring and lever gizmo on the sear that is not found in other 1911s... if you plan to shoot in competition, measure the height of the rear sight, and put a little room temperature vulcanizing silicon sealant under the rear sight, let harden a couple of thousandths high, tighten it down to measured height... make sure none got into the firing pin tunnel if you removed the sight adjustment screw ... this will help keep the sight pivot pin from shearing...
