Another drop to get it sold - STRIDER SNG S110v 3/4 grind
LegendD2
Feedback: +244 / =0 / -0
Strider sng Lego in s110v steel. This one is a user. The previous owner did a terrible job sharpening it- I cleaned the edge up on my edge pro- I basically just had to lay the edge back farther then I normally set my knives- probably doesn't bother most ppl. It could definitely be touched up again towards the tip- the rest of the blade is very sharp. The scale appears to have been coyote brown at one point then dyed black. It's very hard to see but you can make out a little brown in direct sunlight ONLY on the backspacer part and on the inside. Again it's hard to even notice - but full disclosure. Rit dye is available almost anywhere and is very cheap... Would be easy to finish dying it. Smooth action, solid in all directions. Locks up around 50-60%. Centering is SLIGHTLY off towards the scale side- if I didn't mention it you probably wouldn't notice ((but again- full disclosure ))
So basically it could use a sharpening at the tip and in the right light you might be able to make out some very dark brown on certain spots of the scale ...
THE GOOD is that it's a solid, smooth, s110v 3/4 grind SNG you won't be afraid to use
$285 net
PayPal only- immediate payment expected. I can not hold.
USA only
No trades
Strider DB - SOLD In the fixed blade section I have a SOLD SOLD SOLD Stride DB - monkey edge- in 3v steel. View here : http://www.bladeforums.com/forums/s...edge-Strider-DB-in-3v?p=16102518#post16102518
Microtech SOLD - in the automatic section I have a Microtech utx85 SOLD SOLD SOLD m390 all blacked out : http://www.bladeforums.com/forums/s...-blacked-out-hardware?p=16102580#post16102580
