- Jun 16, 2008
hello and thanks for reading. First off ive read alot about flat grinding through the search. I have made a jig as well. 1. the problem is when i free hand i always seem to grind deeper in different areas of the blade.2. the jig seemed to work but i also dont get an even grind......When i freehand i tried the push stick method and ended up grinding into the spine( the blade flat against the platen). Then i freehand without a push stick and kept the spine totally off the platen about a cm.this method also is causing dips and grooves.I know it takes lots of practice but this has been my 12th attempt on some lowes steel and nothing came out to my satisfaction.The only blade i liked was when i started on the platen and the awitch to the slack belt attachment. at that point i was slowly moving upwards (spine up) at an angle and ended up half good.Can anyone add or give me some more insight or technigue. thank you-marekz---besides the slack belt i usually do edge up.---thanks again
