- Apr 6, 2004
So lets assume that I am doing my own heat treat using an old wood stove, and quenching in automatic transmission fluid or some other readily available oil.
What steels would be the best for me to stick to? My first knife was made from 1095, and it seems to me to have worked out fine, but based on info that I have since read here, 1095 seems a little bit iffy for my primitive methods. I have since ordered myself a bar of 1080 which is supposed to be a little more forgiving.
Can you guys list off a few more steels that should work relatively well with my minimal set up? Sooner or later I will get more equipment, like a temperature gage of some kind, some proper quenching oil maybe a real forge or heat treat oven, but for now I have what I have and want to get the most out of the knives that I make using what it available.
Can I assume that the lower 10XX steels (1050 to 1084) are pretty much all OK? Also that all other things being equal the lower ones will be tougher but not hold an edge as well while the higher ones will hold an edge better but not be as tough? Any other carbon steels that would work out OK? Any tool steels?
