Since I usually make sheaths to order I have this knifes without sheaths I want gone. All knifes without sheaths deeply discounted.
I pulled the other knifes to alter the shapes of the handles slightly. If need be will alter the butt of this knife.
Butterscotch Micarta
Handle- 4.28"
Blade- 3.65" edge 3.45" 1/8" stock
Mill/ heat treat flats, Saber grind, dark acid etch.
Handle material- Unique butterscotch cotton micarta buffed shaped with grip slim, G-Flex epoxy with brass hardware
blade Steel Aldos 1084 Carbon steel, edge quench
$90 shipped without sheath
Wood handle for the gentleman
Handle- 4.25"
Blade- 3.60", edge 3.35" 1/8" stock
Drop point shape, Flats mill scale and heat treat finish , bevels hand sanded to 600 grit then etched
Handle material- Cocobolo wood with black fiberglass pins 1/4" stainless lanyard tube, G-flex epoxied
blade Steel Aldos 1084 Carbon steel Edge hardened
In house digitally controlled heat treat
$90.00 shipped, no sheath
Here are the pictures after I altered the butt of the handle
Handle- 4.28"
Handle- 4.25"
