Hopefully this will be my last question(s) about heat treating for a while.
I've got four blades that are ready or almost ready for heat treating, and, after a few unsatisfactory results, I want to get a few things straight before I turn my hard work into crappy knives again although maybe the crappiness is inevitable
I'm using Admiral steel 1075/1080, forging 95% to shape (~1mm edge at quench). I'm not using a calibrated quenchant. I did my first couple of blades in canola oil: the first one didn't really harden, and the second hardened but poorly. I rehardened the first blade using an interrupted quench in warm water for a fast count of three, then into canola oil. It got pretty hard, but cracked. After reading some more and thinking about it a lot, my feeling is that the edge was probably too thin to harden safely in water (right?). Being so thin, though, should canola oil work well enough?
I've been heating my canola oil to around 110º-120º (my quench tub is plastic and I'm worried about it melting. I guess I should just get a better one). I've heard two different recommendations about oil heat: (1) the oil must be around 160º and no hotter than 180º, or (2) that 120º is fine. How big a difference is it going to make if my oil is 120º vs 160º?
Finally, I've heard two different things about normalizing. One method of normalizing says to let the steel cool to room temperature, and the other says to let it cool to 600º. What's up with that?
I'm starting to wish I had gone with 5160 instead of 1075.
Thanks,
Chris
Thanks,
Chris
