another"The Edge" thread
I was wondering why the pilot wouldn't carry even a rudimentary survival kit in his plane? And I mean something more detailed than the bag with survival flare and the shotgun that got left behind. Isn't it mandatory for bush pilots to have such items with them? I know it Hollywood and all but...
AN experienced bush pilot definitely would have more gear. Maybe it was supposed to have fallen into the water, or was misplaced in the crash. But it wouldn't have been as cool if he had more gear on him ;)
I know it is just hollywood & movie mumbo jumbo but make for a good flick huh? 90-98% of the plane we recover or buy do not have anything remotely called a survival kit,our Baron does though,bright orange waterproof bag clearly stamped Survival kit "DO NOT REMOVE FROM AIRCRAFT" and supplies are check 2x's a year.Basic kit has flash light/food/water/shelter/knife(SAK & LM)/first aid. But the kit is just a peace of mind issue only if you survive the mishap 1st.
My understanding is that any plane that flies in Alaska must be equipped with a survival kit as mandated by the state. Now may be wrong, maybe someone more knowledgable should chime in.
You're right--I flew in the Air Force out of Elmendorf AFB for three years, and also flew private planes in the aero club. At the time ('89-'92) you were required to have survival equipment on board any plane, including a firearm. We had cold weather gear and a shotgun on the AF plane, and most private pilots just strapped on a pistol or revolver to meet the requirement.
The weapon requirement was for sustinence issues, and for protection against animals, though not all pistols/revolvers would have been ideal in that situation!
Alaskan Survival Kit Regulations
Alaska state law (AS 02.35.110. Emergency Rations and Equipment) was modified a while back to reduce the equipment required to be carried. The current regulations require that no airman may make a flight inside the state with an aircraft unless emergency equipment is carried as follows:
1. The minimum equipment to be carried during summer months is as follows: (for all single engine and for multiengine aircraft licensed to carry 15 passengers or less)
(A) rations for each occupant sufficient to sustain life for one week;
(B) one axe or hatchet;
(C) one first aid kit;
(D) an assortment of tackle such as hooks, flies, lines, and sinkers;
(E) one knife;
(F) fire starter;
(G) one mosquito headnet for each occupant;
(H) two small signaling devices such as colored smoke bombs, railroad fuses, or Very pistol shells, in sealed metal containers;
2. In addition to the above, the following must be carried as minimum equipment from October 15 to April 1 of each year:
(A) one pair of snowshoes
(B) one sleeping bag
(C) one wool blanket for each occupant over four
As you can see, the Alaskan regulations are minimal and do not address much in the way of specifics or quality. The old regulations were similarly minimal, but required double the food, a gill net and a firearm and specified matches instead of a generic "firestarter." The old requirements were as follows:
a. food for each occupant sufficient to sustain life for two weeks
b. one axe or hatchet
c. one first aid kit
d. one pistol, revolver, shotgun or rifle and ammunition for same
e. one small gill net and an assortment of tackle such as hooks, flies, lines, sinkers, etc.
f. one knife
g. two small boxes of matches
h. one mosquito headnet for each occupant
i. two small signalling devices such as colored smoke bombs, railroad fuses or very pistol shells, in sealed metal containers
a. one pair of snowshoes
b. one sleeping bag
c. one wool blanket for each occupant over four
Canadian Survival Kit Regulations
Canada used to have pretty stringent regulations regarding required survival gear. Then they revised the regulations, leaving the contents virtually undefined and ambiguous, presenting unscrupulous operators with loopholes large enough to fly a 747 through. The current version of the regulation follows, with the former version, a fairly good guide for what may be considered acceptable with modification by some government field personnel, following the current regulations.
Survival Equipment - Flights over Land
602.61 (1) Subject to subsection (2), no person shall operate an aircraft over land unless there is carried on board survival equipment, sufficient for the survival on the ground of each person on board, given the geographical area, the season of the year and anticipated seasonal climatic variations, that provides the means for
(a) starting a fire;
(b) providing shelter;
(c) providing or purifying water; and
(d) visually signalling distress.
(2) Subsection (1) does not apply in respect of
(a) a balloon, a glider, a hang glider, a gyroplane or an ultra-light aeroplane;
(b) an aircraft that is operated within 25 nautical miles of the aerodrome of departure and that has the capability of radio communication with surface-based radio station for the duration of the flight;
(c) a multi-engined aircraft this is operated south of 66 30' north latitude
(i) in IFR flight within controlled airspace, or
(ii) along designated air routes;
(d) an aircraft that is operated by an air operator, where the aircraft is equipped with equipment specified in the air operator's company operations manual, but not with the equipment required by subsection (1); or
(e) an aircraft that is operated in a geographical area where and at a time of year when the survival of the persons on board is not jeopardized.
