- Aug 28, 2020
Speaking of which - is anyone making any full or half backspacers right now? Or will i have to whip out the CAD and print my own?
Wilson combat is the best looking one
Moebius is nice due to its thixotropic properties, but rare to find. Can normally source it from watch manufacturers or jewelry suppliers.
A few questions for the knowledgable CRK folk...
The washers on my sample came a bit rough around the edges:
I think that's the side where the "tag" was when they were CNC'd.
Should i attempt to clean the edge up a bit?
It doesn't seem to have any effect, at least post cleaning and relubing.
Second, there's a tiny bit of wear on the blade (also came that way out of the box) but i can't see what could've made it.
I thought it might've been the lockbar edge, but no, it doesn't come into contact with that bit.
It's very tiny and i'm nitpicking here, but just wanted to check if anyone's seen wear like this and/or knows where it came from.
And finally, third, the clip and the scale beneath it already had wear marks after an hour of (very casually) using the knife out of the box:
I've since removed the clip anyways since i can't stand the thing.
But wanted to ask if anyone knows if Millit clips cause similar wear and tear (at similar speed), cause that's what i'll probably buy and install.
When you do, remove the clip and hold your hand closer to the blade. The position is slightly different than an Inkosi because of the weird lockbar tab, and that in turn makes the clip dig into the palm/fingers even more than on an Inkosi/Sebenza.
CRK really should’ve designed a separate clip for the ‘zaan.
The lockbar tab is a problem only if you hold the knife so your index finger rests/curls over it - it should actually go slightly more forward, in front of it. The thumb goes all the way up on the blade jimping.
When you shift your grip like that, it suddenly melts into your hand. The only remaining ergonomic issue i have with it is the lack of “meat” along the spine of the scales - it leaves an empty gap between your palm along the middle, causing all the force from the leverage to dig the pommel end into your hand in one spot.
Hinderer was really onto something re: ergonomics when he started adding “humps” to handles (Eklipse, Jurassic). It really does make a difference, but i realize it makes handles overall larger and uglier to some. It wouldn’t really fit in on a ‘zaan. A jimped backspacer like the ones i’ve seen floating around here might help that.
FWIW, the original pivot Zaan has a smaller protrusion for unlocking the lockbar, and I find it more comfortable in hand than the newer version with the extended lockbar protrusion.
You’re dead on with what my hand does. Naturally when I open and grip the Zaan it’s not comfortable. If I adjust my hand closer to the blade it feels how it should. It’s a little fidgety for me. The lockbar bar is my biggest issue.
When I open and grip the Inkosi naturally it just falls into place
Thanks for the tip!
Does it get wicked away into the surface like other oils?
I fully agree. I’ve always said I prefer the inlayed Inkosi and PJ 21 in hand. The 21 is more a neutral, one size fits all grip but the Inkosi inches it out by just a little for the win for me.My personal favorite clip is the Hawk. It's smaller so it interferes with my grip less. It really holds the knife in place, important to me on several levels: I'm a cyclist and because in my work (film lighting and videography) I often have to get into cramped positions or up on ladders, etc where it's easy to snag a conventional clip or have a knife slip out of your pocket. Regarding the Inkosi, I'm there with DC Davis, it fits my hand perfectly, especially the inlaid version. But a PJ Sebenza--I could (and do) stare at the perfect balance between grip and blade, the minimalist design, the seamless blend of form and function, endlessly. No other knife has had that effect on me.
My 10 year old Sebenza is free dropping with pressure removed from the lock bar.
My (now) 4 day old 'zaan is almost there already:
Edit: Almost got the silent flick (where the force of the flick is *just* enough to get it to lock completely, but silently) nailed. I can pull it off about 50% of the time. Completely silly, i know, but it's a good stress relief / zen thing.
If i take two knives and just sorta bash them into each other for a few days, do you think that might produce a mix?
