Seems like even in a pretty modern operation, timberfallers still need an axe. Heres a few pics of a sugar pine I had to fall a couple months back.
There was a pretty heavy lean, and not a lot of places to put it.
Not here, thats a 20,000 gallon water system that serves 4 campground and day use areas
State highway, better not.....
And thick woods all around a big tree like this would make a real mess in. But if I can thread the needle, here's a spot, directly opposite the heaviest lean.
Time to get serious. A set of 110 ton tree jack's, stihl 461 w 36" bar, 4 lb Plumb rafting axe. I bored this tree, and it was still plenty sound, but jack's and snags are not always a good combo.
Jacking a tree is a whole different cutting plan. Make the shelf, and backcut enough to get the Jack's in and have room to run the saw without hitting them. Axe is handy here, for removing the chunks. Gun from the backcut to keep it all square as you go.
Load the Jack's and then make your face to match. Again, sure can use an axe. No chasing, no fooling around, very little room for error, especially on a double cut. Gun your face the same as your backcut, so you know where you're at in there.
Check your gauge, and then finish up the backcut, keep checking and keep it on the run. Usually leave more holding wood than a tree you are wedging. Not too much though! Set a couple wedges as backup.
Once you're cut up, you're cut up. Time to finish it off!
The BOOM never gets old
Lot of lift. Wedges wouldn't have really been an option.
Happy cuttin'
Happy cuttin'
