- Jan 10, 2015
A17- depends what you are doing with the saw and how tall you are. For the 075 I kept a 36" bar. That allowed me to fell and buck the bigger dia. sticks. Now the 056 super was my saw for swamping, felling, limbing and bucking. I kept the 056 with a 28" bar. In a full on production mode, for my height, and most dia. sticks, the 28" allowed me to do all 4 operations with just one saw. The critical factor is the limbing. You have to have a bar length that allows you to carry the saw with comfort and just reach the ground with the tip for limbing. That allows you to carry without adjusting your hold over and over. For my height and hold position that was 28" with the 056.
Mule man- the bell base jacks would still have a use in the wilderness areas where your jack would not be allowed. One trick is to make up a steel plate to span and catch the top of both jacks. ALWAYS use 2 jacks. Weld some short sections of pipe to the plate for the target heads to fit in and be captive. Also, if the jacks have swivel heads, weld them so they dont swivel. You want the heads to still rotate, just not swivel. The down side of this top plate is that you have a extra projectile if something goes sideways on you. The trick to the 2 bell base jack operation is that you have to learn, by feedback from the handles as you take up the jacks, that you are exserting equal lift with both jacks. This is some thing you learn from using these jacks often. Last thought- NEVER and I mean NEVER do this with automotive style hydralic jacks, you get no feed back.
