- Oct 25, 2002
I would love to apply an antique finish to some of my knives. Any of you guys ever do this? If so, what are some techniques I could try?
thanks!
thanks!
America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
Mark Williams said:I apply tool-black and then soak in ferric chloride. I have been know to use
a little bit O' pee pee.
Vinegar works , mustard. Tomatos.
Will52100 said:one thing you can also try is mustard. Regular frenches mustatrd. Put it on and leave it for a few minits and then was off. try several differant methouds. I like the mustard because it's slow and you can put the majority of the pattina where you want it.
Steve Hayden said:I use the method I learned from Chuck Burrows (Wild Rose Trading Co).
Give the blade a good coat of cold blueing-I use Birchwood Casey's Super Blue. Then immerse the blade in Clorox Bleach. Let it stay in until it is coated with rust, then let it air dry. Remove the rust with 0000 steel wool then fine sand it and use a alkaline solution like baking soda to neutralize it. Repeat as needed to get the surface you are after.
The degree of antiquing can be controlled by the time in the Clorox. I left a D2 blade in overnight by mistake once and it looked like it had spent 30 years in a barn.
Mark Williams said:I have been know to usea little bit O' pee pee..
cwend said:am i the only one sittin here laughin so hard im cryin at this?? maybe ive been up too long...
Listen if he look at a blade that was polish it would crack. So he pee's on them so he can look at them.cwend said:am i the only one sittin here laughin so hard im cryin at this?? maybe ive been up too long...
Cousin Jack said:Ever try soaking in bleach first, then applying the blue?....Also, will spraying the blade with windex neutralize it?[/QUOTE
Yes but it doesn't work as well - you can use only the bleach itself, but it is slower - the Super Blue acts as an accelerant. And yes any ammonia based product will work for neutralizing but the baking soda water is less nasty to work with.
Here are samples of three blades (all 5160, all with a forge finish spine followed by the blue/bleach etch - time in the bleach varied from 5-20 mintues):
peter nap said:I have one very talented rifle builder on my site that goes whole hog with the aging. After some mild abusing, he will paint the wood with rustolium (Black) and then sand it off.
This leaves black in the dents and looks just like the grime deposits after years of handling.
