HI all, been reading this forum for a while, learning about knife making and blacksmithing from all you folks here. Thanks a bunch for sharing your knowledge!
I started knife making a few years ago, and took a long break before I finally started back into it. Now I wish i never quit... Long story short, I began smithing on the infamous RR track anvil, about 14 inches stood on end and have grown tired of the small work surface after two years and multiple larger projects. Yes it works, but it sucks for bigger work (bigger knives, hammers etc). Which brings me to the point of posting:
I have sourced several large chunks of steel in the 75-120 lb range of unknown composition and will be converting them into some anvils to replace my RR track. I have no clue what they were used for, nor the exact composition.
There are a few options here,
1) One piece is 3.5 inch square shaft and about 24 inches long, I will use as a post anvil.
2) There are two 3 inch thick plates 14 inches wide and 2 feet long. In your opinion, should i make an anvil out of one 3 inch plate or should I weld them together for a 6 inch work surface? I think the joint running the middle of the surface might create a dead area and eventually break the welds, so it may be more effective to shape the 3 inch plate instead rather than have to re weld ti later? Though that's not a big deal...
Thoughts?
Thoughts?
