Any comments on the CS Bushman?
I was wondering if anyone has used or tested the CS Bushman? They claim that it is the best survival knife you can buy for under 20$. I think they have upgraded to steel to CV from the plain high carbon steel. Is it close to being true or is it all hype?
Improvise, adapt, and overcome. Words to live by.
I gave one to a woman I know who used it first thing to clean and butcher a freshly killed rooster, for dinner. It worked great for her.
They are usually shaving sharp out of the box. I have tested mine on the end of short and long sticks as a spear, and it is safe, in my opinion for thrusts to soft tissue areas or for very clean long-range slicing or even chopping at smaller branches.
I didn't feel confident thrusting into hard targets with it on the poles due to the thinness of the blade -- and especially not when it in the hand as is: no guard! In the past, they've had weaknesses at the joint of the blade and handle, but Lynn Thompson was contacted by some experts who had the problem, and the problem was, I believe, corrected.
It makes me nervous as a thrower when used as a spear, and I do think that if it stuck into bone and was twisted sideways, it might snap at the blade juncture when attached to a pole.
That said, it is a GREAT and useful knife at $20 -- you can literally sharpen it on a rock if you don't have a sharpener.
Hope this helped...
Brian.
Not the best knife in the world, but the best knife in the world dollar for dollar. I bought 5@10 bucks each, and have them scattered about where I usually am. They are great utility knives and if anything happens to them, well, your out 10 bucks.
I have a CS Bushman, and it's a pretty neat knife for the money. Yeah, there is handguard, so stabbing would be risky, but I only chop and slice anyway. The knife is well balanced, and the steel handle is actually pretty comfortable for me.
For those concerned about a slippery bare handle, you might be able to put a rubber or neoprene cover of some sort over it, like those used on polymer pistol grips.
I view it as a great "learning" tool. If you lose or it damage it, you aren't going to feel as bad as if you just busted a Randall No. 1. Lately, I've used mine to practice flint and steel fire-making with one of those flint/magnesium bars.
This is my first post, so bear with me. I've honestly tried to destroy this knife. In the begining I just wanted to determine about how much abuse it could withstand (within reason, of course). But, after failing to damage it in any way i preformed tests that I thought it would fail. I then stabbed it into metal thicker than it could puncture; yet there was only slight damage to the tip. I was impressed, so next i proceeded to stab it into trees, hack at limbs, and just generally attack the underbrush of the woods behind my house. Oh I also used it as a throwing knife (to the best of my abbility).
After all that i was exhausted (not in the best of shape), I started my way back to the house, and while examining the blade I found that I had only managed to slightly curl the edge, as well as the tip damage I mentioned earlyer. I was impressed, I hardly expected it to preform half as well as it did.
conclusion: for 20 bucks, your not loosing anything in my book.
I had one for a while and I thought it was an awesome knife for the price I paid.
Sharp, strong and reliable; what other $15-20 knife can you say that about?
The vague and tenuous hope that GOD is too kind to punish the ungodly has become a deadly opiate for the conscience of millions.
*A. W. Tozer
2 Cor 5:10
My father had two things on the back window of his truck when out and about; his Ruger Mini-14 (combo-locked), and get this, a Bushman with a handle from a paint roller shoved in the end! He also took rubber radiator hose from an hold big block, cut it to length, and slipped it over the handle. I don't know what adhesive he used, but it held for two years with little or no play. To increase grip, he cross sliced the rubber, then melted it down a little in some places.
Tough knife, many applications, tough company...
God's choices in inflicicting suffering are unsatisfactory to us, nor are they understandable, unless innocence offends him. Clearly he needs some help in directing the blind fury with which he flogs the earth...
