I just finished a knife for my dad. It's 8 3/8 OAL little under a 4 inch blade made of A2. It ended up about .215 thick after I got the stock straightened out. This will be the fourth knife I've done that isn't a tanto so I had to try and get the grind as good as I could without hand sanding to straighten out little imperfections. I got a little wobble on the grind line on one side the other turned out pretty good. I did have a problem of getting a little dug in part 1 inch away from the plug line because I'm using a 1x30 grinder. I think maybe I was sitting a little crooked compared to the grinder so it through me off. In the end I think it looks ok and I'm sure my pops will be happy with it no matter what so I thought I'd get you guys' expert opinion. Thank you.
