The littl grinder that Lynn purchased is a fairly nice little grinder for the money.
It's often hard to find a nice surface grinder used that's gonna hold any kind of tolerance.That's usually why the machine shop got rid of it to begin with.Although I have seen exceptions to this occasionally.When I have,the grinders went for a good chunk of money.
The grinder from Harbor Frieght is built very simply with scraped ways on it.Some old machinists actually prefered these.They work real nice IF You Take Care Of Them!!
The problems occur if and when the ways get to worn.
Cleanliness and proper lubrication is the key.
This type of machine was all there were for many years in this country and they helped build the newer fancy ones with all the bells and whistles.
Some of them are still in operation today because they still do the job.Some of them have some awesome material capabilities as to size!!
The only thing I had against the one Lynn bought is the table handle for end to end grinding.The handle setup isn't the easiest to operate.Lynn and me discussed that and what would improve it.
The in and out feed is easy,
because you only move it at the end of each completed pass.The end to end feed determines a lot of how long the wheel lasts and the finish on the part.
Another key to satisfactory surface grinding is the quality and hardness of the wheels a person uses.
A softer wheel will wear quicker,but it can produce some awesome material removal without burning the work.
I spent the last year and a bit of my 35+ year career as a machinist as a tool and die grinder and maker.Our company had the largest amount of automatic screw machimes in the area.That along with the 2nd operation dept.and some punch presses and milling machines
kept me in more than I could do.
I miss the work.Enjoy it while you're young and healthy.
I always Loved My Work,But I didn't always Love my Job.
I bet there are a bunch of you that are the same.
>>>>---¥vsa---->®
If you mix milk of magnesia with vodka and orange juice do you get a phillips screwdriver?
Khukuri FAQ
