Cliff Stamp
BANNED
- Oct 5, 1998
Gteckwreck said:What's the major problem with establishing a set of standards for testing of knives similar to those of ASTM? ASTM standards are used extensively in my profession, architecture, to establish criteria for performance exclusive of design, ie, subjective requirements.
Nothing, in fact a large amount of such tests already exist in the form of standard materials data. These are tests like strength (tensile, compression, torsional, fatigue), impact (charpy, izod, torsional), wear (abrasive, adhesive), and corrosion (acid, salt spray), plus micro-graphs of the steel (at multiple RANDOM locations) to show the grain structure and level of carbide segregation. These tests are very definate and can all be done by INDEPENDENT sources so you are not depending on a maker/manufacturer doing a critical analysis on their own steel. Do you really want the carpenters who build your house to be able to inspect and pass their own work? Of course not, this would be so naive that everyone would immediately see the gross problems it would present.
Now with the basic materials properties defined you need to figure out how these actually translate to the knife in use. This is the current weak point because there is little done in this regard and often a lot of it is just based on assumptions which are often based on someone just selling something. If a steel tests really well in a certain measurement then all of a sudden that measurement is the critical one for knife performance. The problem that many have is waiting for some perfect set of tests. You don't sit in a lab and just think about how to collect data, you start doing it and refine the process through the experimentation. Your first results will be rather rough, you might even never publish them, but the growth is exponential, the more you learn the faster you will refine the work.
At a basic level I would just like to see more makers with definate measurements. Note only the type of grinds but the extent, what is the angle of the grinds, how thick is the edge. Where are the balance points, static and dynamic. Then of couse you add PUBLIC statements about thier knives versus specific benchmarks. As simple as "I compared my blade vs a 154CM blade heat treated by Paul Bos and the performance was increased by 15%". Now once this starts you can start to refine how the tests are performed, but you have to get the work started first. Without reference points there is no way to tell if the performance was impressive or not.
"I cut up a coffee can and the knife still easily carved wood. This is some impressive steel."
Really? You can in fact do that with a $10 machete. Ideally the reference points are the same for every maker. But get reference points used first and then worry about getting them the same. Kevin Cashen is leading a huge push to get makers to do this type of work. Manufacturers like Spyderco and Busse Combat have always done it. They each do different things, but will both be clear how they are determining performance when they develop their knives. There are custom makers with similar methods. Goddard and Wilson always use specific benchmarks and will tell you in great detail how they do the work so you can confirm/refute it.
If you ask Wilson for example about edge holding he doesn't say something like "The edge holding is excellent, I made 367 cuts on hemp before the edge was dull." That doesn't mean anything because there is no refernce and you don't know how the cutting was done. What Wilson will say is more like "A friend and I did some cutting and through an average of six rounds we found that there was a 20-30% increase in performance over ATS-34 in slicing 3/8" hemp. We stopped the cutting when the blades took more than 20 lbs to make a slice. The edges were all about 0.005" thick and sharpened on a coarse silicon carbide stone at about 15 degrees per side."
As a user you can be more demanding, stop taking the sparce materils data from maker/manufacturers and ask for the full spectrum of information not just the hand picked tests for which that steel excells. Whenever a maker/manufacturer starts promoting impressive performance then ask for definate benchmarks and reference points. Whenever there are claims of superior performance ask for the corrosponding weakness - it always exists. This will not make you very popular with the hypesters, but you will be very welcomed by the makers who are seeking performance.
-Cliff
