The only knife that fights for pocket time as much as my delica is my kershaw skyline
hmm, thought it was because i owned a kershaw blur that had it. thanks.The Kershaw Skyline is not assisted.
I find the Delica 4 FFG to be my favorite EDC. There's a few blades that make it into rotation, albeit, not quite as frequently.
1. Cold Steel Mini AK-47. Love this blade. Dimensions almost identical to Delica but not a FFG. I like the inclusion of the pommel. Find it's very comfortable in hand, lightweight, ABSOLUTELY ZERO blade play, and the same pricepoint. Aus8 steel, which is adequate, but not as good as VG10 by any stretch of the imagination. Awesome blade. Only minus is the G10 is so grippy it'll tear up your pockets.
2. SOG Aegis. A few dollars more. Has assisted opening, which isn't necessary imo, but does make this knife super fast upon deployment. Very light. Just slightly larger than the Delica. Will run you about $60. Again, adequate Aus8A blade. There is very slight blade play side to side, however.
3. CRKT Ripple. Another lightweight blade. I have the cheapie version that Wal-Mart sells, I think the more expensive version has had questionable quality in its bearing system. $35 for the cheap version. Great little EDC folder, pretty solid for its pricepoint. Steel is of lesser quality, though, and not nearly as ergonomic as the Delica.
For the $$$, Spyderco just puts out a great blade that few match. That Cold Steel is super impressive and a tight run for the dollar against the Delica in my eyes. It just misses the bar by a few millimeters with the slightly too aggressive G10. Spyderco's prices seemed to have moved up this year. I prefer Spydercos for their value and performance. Another price push upwards, though, and I may sway with my "favorite" brand as there's plenty of options for great production knives.
any blade play on your delica? i've been reading a few reviews, just a few, that complain about some blade play.
None. Lock up 100% and no wiggle anywhere. I had to lock-tite the screws on the clip, as they did loosen from factory. I know I had a PM2 I sold that came from factory with screws that would not stay seated...also lock-tite. But as far as blade play on the Delica, none. That said, if I was to compare how I feel about the strength of lockup between the Delica and Cold Steel...Cold Steel hands down. If I was to abuse and beat on these two blades (not that I would) I would expect the Delica to fail the very first hard-use test while the CS would live to see another day regardless of what I put it through. Thing is like a vault, and you can tell by feeling it. Just inherent in the design, and obviously neither is truly meant for hard-use duty, just throwing it out there.
If you're interested in the Delica, I'd suggest looking into the Spyderco Stretch. It's about the same size, but with a little more blade, a far more practical blade shape, and improved ergonomics. It's one of the best values for the price.
Also, consider a 555 mini-grip. It deploys much faster than the Delica and has a similar blade shape.
