Maybe I'm misunderstanding the link, but it seems to be speaking of subjective brightness rather than absolute. For example:Originally posted by R.W.Clark
Yes, the article does state that at the same level of intesity green will damage your night vision more than red. However, the point is that you use a much lower light level with green than with red. This is due to the fact that the human eye is more sensitive to green.
With the Photon III you can adjust brightness. Therefore you will get better results from green then with red because you can lower the light level.
I would be very surprised if green were superior for retaining night vision given that astronomy lights are always red.Green or blue-green has a greater capacity to adversely effect night vision because the eye is about 100 times more sensitive to these colors
I believe that at least part of the reason is that green illumination doesn't show up well on night vision equipment, whereas red stands out like a beacon.Originally posted by Allen E. Treat
R.W.Clark -
Then I wonder why the U.S. military
switched to green after all those exhaustive studies they did in the 80's.
AET ( former 11Bravo US ARMY )
Originally posted by tribalbeeyatch
For example:I would be very surprised if green were superior for retaining night vision given that astronomy lights are always red.
Green light is best for seeing under the low light levels needed for reading star charts while observing. Seven out of eight deep sky observers will be able to see fainter objects when using a dim green light to read star charts!
Originally posted by Bali-Flipper
Surefire sells a filter ofr their flashlights that is an infrared filter, but isn't infrared invisable light, so isn't that kind of an oxymoron? What does it look like with that filter on.
Sorry for the confusion, Mike. I HAVE read and understood the astronomy link. I'm an amateur astronomer myself and am well familiar with Mr. Kniffen's assertions about the supposed superiority of the green LEDs that he sells. I've seen this issue debated on astronomy boards before, and I can't say that I've ever been particularly convinced by the pro-green case. And I wouldn't exactly call Mr. Kniffen an unbiased source because of his vested financial interest in the topic. Actually, his article made me more skeptical than ever given the way that he seems to spin well-established neurobiological facts to suit his agenda. Suffice it to say that the superiority of green light is not as clear cut as he would have you believe. It's not a simple matter of red lights being "old school" and green being the wave of the future. In fact, other than the product that Mr. Kniffen sells, I can't think of a light that's sold for starcharts that isn't red. Here's an article that gives a better idea of the controversy over this issue:Originally posted by Medic1210
Did you happen to check out the other link on the original article? It plainly states that green is better for astronomy. Be sure to go back and check it out. Here is a quote from the first line of that article written by an astronomer.
Skiff also claims that "there is ample laboratory evidence to show that red light allows you to become dark adapted after exposure (even at very low levels) about 4 times faster than with green or white light."
Jeff Medkeff, the Acting Assistant Coordinator for the Association of Lunar and Planetary Observers, Solar Section, joined in the discussion in support of Skiff?s claims, citing the specific JOSA papers (listed at the end of this article). "Brian is totally and completely correct" Medkeff asserts strongly, "to say that you get the dark adaption back quickest using red light at the intensity necessary for reading, then any other color."
