any Shirogorov 95t experts can explain to me what the difference is between the old and new model?
To my understanding, the new model uses a new triple bearing system where as the old model only uses a single one? is that why the price difference between them are around $300 ($800 vs $1100)? and is that basically the only difference between the old and new model?
when did this old/new model transition happen? In my research it seems like late 2016?
and finally im guessing this one listed below is the new model right?
https://recon1.com/product/shirogorov-95-t-pattern-m390-blade-titanium-handle-mrbs/
thank you in advance for your help!
There's an explanation for what you are looking for on another forum, I'll message you the link.
Edit: actually I can't message you because of your member status or cross link to another forum.
To answer your questions:
-The model on Recon1's site is the latest version (I just received one from them)
-This change happened around February 2017
-Interior milling (weight reduction)
-Updated blade grind (old was full flat)
-Updated gimping (more pronounced)
-Updated to MRBS (earlier versions had washers)
-Updated rougher tumbled finish (better at hiding scratches)
