well, then I will make one for you!I'm still in for a DEK1.![]()
why, thank you! Glad you like it!I just realized that the last sheath we talked about was for an FK.
Things have changed, lol. Nathan should have a SWEET african blackwood DEK1 ready for me towards the end of the year.
P.S.
Your Kephart sheath is holding up really well and is easily the best sheath I own.![]()
Looking good! Stay positive my friend, stay positive.![]()
it's all together, just gotta dry out and then I'll treat it. I've been wanting to do a camo dye job and I think I might experiment with this sheath.
So far I'm really happy with the way it turned out, but you never know for sure until it's 100% done. Still opportunity for problems![]()
first of all, thank you!Lorien,
I love the design and how your leather sheaths lock the knife in place. Can you describe how you accomplish this and where the sheath locks onto the knife?
I have several CPK's that have a satin hand rubbed finish and wood scales. Will your sheaths be less likely to cause blade scratches or damage to the wood scales vs a kydex sheath?
Thanks for the detailed explanation Lorien. Looking forward to see what you come up with next.first of all, thank you!
the knife is locked into place by a combination of welt design and wet molding. The welt design determines the angle of release so I can really dial in the thumb break. The wet molding allows the leather to conform to the handle's shape and determines the level of retention. For this model, high retention is a design goal, so the throat of the sheath is heavily molded.
there is nothing about the sheath that should cause scratching or staining. These sheaths in particular are waxed inside and out, and none of the sheaths I've made in the past using this method have caused or contributed to staining or corrosion, in my experience. Because the inside of these sheaths are waxed, it's much less likely that a grit of some kind that works its way in there is going to get caught up in the fibers of the leather because they are compacted and coated. The way the sheath is made, the sides of it are not pressed against the bevels and the welt is fairly thick, meaning there is quite a bit more space and much less of the inside of the sheath touching the steel than a kydex sheath, generally speaking.
the throat of the sheath is heavily waxed, and barring some grit getting lodged in there, should have no effect at all on the handle.
Great to hear, thank you!I've been using one of Lorien sheaths with my CPK Kephart (machined, walnut scales) for almost a year now. There hasn't been any damage to the blade or scales. The retention system Lorien has implemented is rather ingenious and super secure.
the timeline depends upon when I get close to the number of committed buyers I'm looking for, (around10). Ideally, I'll start cutting leather in a couple weeks. I'm not in a rush, plenty of projects on the go.
my dyeing method takes days, between adding layers, letting them dry and then buffing. Usually 6-7 applications to get the effect I want which is durable and has a nice chatoyant effect. The process also doubles the hot waxing time, since the wax uptake is slower. If I started off with pre dyed leather, it probably wouldn't cost more but it also wouldn't be the same look and feel that I want from my work.
my plan is to make another sheath and not dye it, then I'll have something to show which represents what people will be spending their hard earned bucks on. It'll also help me dial in my process a bit more before I start making a larger batch
