Any tips on working with macarta?
Robert,
Did you get the buffer at Sears? I need to purchase a real buffer rather than using my converted bench grinder.
Post some photos when you get done, so we can see the final results.
Mike L.
Do you still need to wear a respirator when hand wet sanding, or only when grinding with power equipment?
I probably wouldn't wear a respirator with hand wet sanding. The water will keep the dust in slurry for the most part. If you're worried, a simple little dust mask will work for hand sanding. But still need the respirator for powered work.
--nathan
Another tip,get a piece of auto heater hose,split down the middle,tear off a piece of coarse cheap sandpaper.Then put one end in the split and wrap the rest around the hose,works great for finish work,finger grooves,etc.Regards Butch
