- Jul 17, 2005
Is that square silvery thing a grill? On the left at ground floor level, just behind the rainwater downpipe.
Can power lines attached to a brick/masonry outside cause a low hum or drone?
If it is power lines, would the sound still be omnidirectional or would I be able to locate the sound where the lines connect to the outside brick wall?
Arthur, excellent! thanks...
I ask because the sound seems to be omnidirectional, not loudest in the room where the lines connect.
Say the transformer on your pole is going bad. It could be giving off noise that we are unable to hear but will transmit that vibration through the lines then possibly something in your house is conducting the sound and causing the noise. Thats where the Ultrasound device comes into play. It can listen to the electrical system and detect the noise possibly allowing the elec company to repair or replace what is going bad saving them money and you the sound problem.
When you turn off the main breaker in you panel all your shutting down is everything on your breakers. The service cable going into your panel is still hot (live). Electricity causes vibrations which causes loose connections.Well yes. If you switch off the power at the box, then that shuts off all the applicances in your house, but Arthur's excellent suggestion is that the transformer is buzzing and transmitting the sound to your wall. The fact it is carrying electricity is irrelevant, it is transmitting sound, not electricity to your house via a taught wire. Not being funny, but when I was at school we did an experiment with a couple of baked beans cans and 20 foot of tightly pulled string attached to the bottom of the cans. When one person talks into the can, the other person can hear the words by putting a can to the ear. The electricity transformer is talking to your house via the taught wire.
