- Oct 1, 2012
I see. Thanks. I don't think this will do much for airflow, but then you didn't mention this as your reason.. The hip joints would not really be affected.
Right, I was making the point that it was fine to hang them head down for skinning with a split pelvis.
So you only do this for removing the ends of the digestive tract, I assume? Or do you see some other benefit?
You do have a little better air flow by splitting the pelvis because the animal can be opened up farther. If you need to get it cooled down, though, I think I'd just get that skin off and start quartering. But I think most people split it to get a straight shot for cleaning the digestive tract out. If you split it out in an elongated 'X' rather than straight down the middle it does make a nice open channel for gutting. Like I said, though, I'm not really purporting one way over the other, I have done both many times. I do not like to split the pelvis if I have to drag the animal very far because that slight increase in air flow is also going to get you increased exposure to dirt. I would look at it like this:
Split Pelvis Pros vs Cons
Pros
-wide open channel to remove what needs to come out.
-hind quarters lay out flat for some air flow.
Cons
-increased risk of busting the bladder or perhaps ripping the colon.
-takes a few more minutes to get finished.
-opens up the carcass more to dirt and flies.
I'm sure there are some others who can add to the list of pros and cons, and I'd certainly welcome that. :thumbup:
Cheers,
Dave
