- Jul 23, 2007
Really like the buck vantage as a user knife
Unless it is so bad that the blade rubs against the liner, I think blade centering really is an aesthetic issue that is seen as a proxy for quality (and rightfully so I suppose). The action on my Vantage is so underwhelming that a perfectly centered blade isn't going to make it a better knife.The one I had bought had perfect blade centering.
With the 110 LT being $20, I see it as good as the Vantage.
I love my Buck Vantage and still have it. It's a large FrankenVantage, cobbled together with a Pro S30V blade and the Dymondwood handle from an Avid which I dyed darker with RIT dye, polished up with a superglue "varnish" layer, and finished off with a little polymer clay "medallion". I also polished the washers and liners, recessed the presentation side liner to give my thumb access under the scale for the liner lock, and reprofiled the linerlock for ergos. Silly little mods, but it made the knife mine. It was my first EDC blade and the knife I learned to sharpen on, and I carried it until Hinderer designs kicked it out of my pocket. Still love it though.
Btw, I found centering fairly easy to take care of on the Vantage. You just have to imagine the two sides of the handle as parallel planes with misaligned pivot holes which causes the blade centering to be thrown off. So, with the knife closed, hold it so the tip is facing you and you're looking down at the blade spine. If the centering favors the right side (presentation side), then just loosen the screws, shift the right handle towards you and the left handle away from you, and retighten the screws. You may have to take the scales off to access the screws for the standoffs and clip "backspacer". But I was always able to get good centering and decent action. The same trick helped me center up my Hinderers.
more than the 420hc ones. maybe not quite double going by memory but close to that.I did not know buck used sandvik steels for the avid versions. Were these comparably priced to the 420HC versions or double or triple the price?
