Anyone else make their own resin bonded stones?
It seems pretty great, but I still don't see the results clearly. I tried sic this way but failed, probably only diamond is suitable
Well, with sic you need very little resin. The material should be kinda dry and pressed down to bond.
My sic stone had too much resin. It does work but not as it should.
Chà, với sic bạn cần rất ít nhựa. Vật liệu phải khô và được ép xuống để liên kết.
Đá sic của tôi có quá nhiều nhựa. Nó hoạt động nhưng không như mong muốn.
Để làm được điều đó chúng ta phải có máy ép nén, không thể làm cách khác được
I tried and failed less than 6 times. If I mixed a little more epoxy it would be the same, but if I used less epoxy it would be crushed due to insufficient compression.
Honestly, with a 15$ jack you can get up to 2 tons of compression.
I'll try to find one and give it a go. I'll share the results
I used up to 10 tons of compression force, but it still has something strange and not simple
My understanding is that the pressure used industrially is more on the order of hundreds of tons.
Hi all,
I found this thread back in October in my search for a "how-to" on resin bonded stones. It is AWESOME! Thank you to all of you who have added to this thread - you rock!
Since October I have been messing about with making the best recipe for a resin bonded diamond stone under a given set of limits, i.e. the resin I could get my hands on and what I could do in my shed etc. It has also been a great journey in multivariate experimentation, which in part has been my excuse for spending money and time on this project. There has also been numerus side quests; i.e. how to make a mold, how to make a consistent (objective) measurement of the quality of the stone, discussions with my really clever organic chemist friends on epoxy chemistry, and then redoing most of it, because I have learned something new. Great fun - all of it!
Below is the stones I have made so far - and this is only for stones with diamonds with a mesh size of #400 and a bit less of #1000. Yeah - I also messed up the difference between mesh size and grit - something that I still have to figure out.
I do not really have much to add to all of the above, except the call to action, this is great fun!
/Kraftcorp
Hi all,
/Kraftcorp
Excellent. Make sure to please share your findings and what you learn here so everyone can benefit from it!
A few years ago I did some experiments using shellac based off of the "Fernsler Ruby Hone", which is a barber sized razor hone. I had some limited success so it may interest you guys. I bought prediluted shellac from the hardware store, and did basically what the contributors to this thread have done with epoxy. Mixed a paste of .5 micron aluminum oxide and spread it onto a strip of stainless and waited for it to dry. It works, and I still have the stone, but as it dried it started developing fine cracks all over the surface. It's stayed in one piece, and is still usable for edge trailing strokes, but it lives in my collection as a novelty rather than a stone I use. I read later that comercial stones made using shellac as a binder are also heat and pressure treated which may give them the stability mine lacked but never persued it further.
I also tried epoxy, but used a resin that was too soft, and too low of a ratio of abrasive to resin. It was slow cutting and gummy, and it didn't expose new abrasive. I would try epoxy again, but would want to try a much harder/brittle resin in the hopes that it would allow some friability and expose new abrasive.
Lastly I tried thermosetting resin, Cactus Juice used for vacuum hardening wood for scales. It had the same issues as the epoxy with the added problem of bubbling and foaming while setting. Others may work, but this was a total bust.
Lately I've become interested in this again after buying and being somewhat dissapointed in the slow cutting speed of a Hapstone 100 micron resin bonded diamond. They use a reportedly non toxic plant fiber based resin which I assume is a lignin based replacement for phenonlics. I've poked around a little, but can't find anywhere a layperson can buy resins of this type, or information on how to use them.
I've also been interested in using "microballoon" fillers to thicken the mixtures and cut back on the abrasive needed. They're available made from aluminum oxide in various mesh sizes, so they might pair well with diamond powders to reduce the diamond needed for a given stone, and possibly increase friability of the stone as they break down.
Hi all,
/Kraftcorp
I am extremely interested in this and would love to find out more. I have been harassing diamond abrasive and tool/diemaker stone suppliers all week with emails and questions. I already have some canvas backed diamond sandpaper, and diamond plated foil to experiment with, but what you are playing with would be my holy grail.
