- Jul 28, 2006
Anyone used Itsaburl off of fleaBay? Did you have any issues with the wood not having full penetration of the stabilizing medium?
I am the guy at it's a burl who prepares and sells the knife handle wood. Most of the knife handle wood we sell is natural, unstabilized woods. I do stabilize some, mainly spalted maple, buckeye and redwood. The method I use involves submersion and soaking, not vacuum chamber. Most will be done using a product from Protective Coatings called "Wood Petrifier". It is used primarily for restoration of rotted architectural pieces. I like the fact that it is waterbased and non toxic. Full penetration for scales or a 1.5" thick block takes about 1 week. I put a test piece in with the batch, which I cut in half to check for full penetration of the wood. This product does not make the wood as hard or heavy as with the stabilizing companies who use a vacuum chamber and acrylic polymers. The wood still finishes and feels like wood but has been sealed and hardened. This is the same process I use for my own knifemaking projects. It is easy and an inexpensive way to do it yourself if you don't want to use the stabilizing companies. Many of our customers will get together a batch of wood from us and send to the stabilizing company they are most comfortable with, for stabilizing. That is our recommendation. Stick with the guys who prepare the handle material the way you like. Our main goal is to provide cool and unusual wood unlike your other suppliers. I hope this helps and answers your questions Will. Thanks, Mark at It's a Burl
I may take your advice and post some when I get back from the Eugene Knife show. Thanks for the good idea. Any ideas what I should list; blocks, scales or bigger pieces to cut your own? Any input is appreciated. Thanks, Mark
