It finally happened, I bought a pair of 'nice' jeans...
The main way my pants wear out now is the pocket gets all chewed where my knife clips and my girlfriend yells at me to get rid of them.
I've tried sanding the g10 under pocket clips and decreasing tension on some clips but neither of those fixes work on all knives (eg: customs with sculpted clips)
I've also seen some people who've added a piece of leather to their pants pocket, I'm hoping to find a more subtle solution than that!
I know this isn't the first thread with this idea but I've searched and read and found nothing to end my ruined pocket woes.
So... anyone have a subtle, reliable way to decrease pocket wear?
Thanks for your help!
-jeremy
What causes the wear is the friction between the clip/knife and the pants material. So to make the pants last longer we want to reduce the friction. Well, the force of friction is defined asThus the only way to reduce the friction is reducing the normal force (F(subcript)n) or the frictional coeffeicent. We can reduce the frictional coefficient by polishing all contact areas of the pants and knife, including the handle and clip, VERY FINE sandpaper would help a lot. I am talking about working your way up to 8000 grit. The other way is to reduce the "Normal force", which is the force the pants exert on the clip, the only way to reduce this is by loosening the clip. Finally the final way of reducing the rate at which you wear out your pants is to stop wearing jeans and wear something with a smother material, or find jeans that are not very course. How did I do on the reply guys?![]()
Yeah... I blame my senior year physics class. I will be working on my degree for mechanical engineering soon.
I quit using pocket clips. Problem solved.Anyone found a way to prevent destroyed pockets?
Thank you and excellent post, if I may add unto your recommendation, salvage from my knowledge is the most durable denim. It is also the stuff your grandpa wore.Great response from the mechanical engineer.
My recommendation is to choose a more durable denim. The market, and therefore the options, for high weight denim are increasing. The vast majority of these hold a premium because of their higher quality materials and hardware, or because of the added costs involved in manufacture.
The reinforced jeans from Wrangler are an option I have yet to explore, but I have heard very good reports from users that carry knives in those reinforced pockets.
On a tangent, there's probably a little more friction after a certain point with clip smoothing. As you approach a mirror surface, you will find that the greater surface area of the clip contacting the fabric exceeds the friction reduction by removing the coarse surface. The sharpening guys might describe such as "stiction".
Buy more pants and jeans.
Everything wears out, knives, pants, cars, and many other things. You can prolong the life of anything but eventually there is a end.
