Buy the 760 for it's superior cutting performance if you're okay with a single thumb stud and tip down carry, you buy the CRK for it's fit/finish/status. The 761 seems to follow a lot of what was good/bad about the older BM 760.
I own a 25, and handled a couple of the 761's at Shot. The 761 fit and finish was very nice, feels pretty good in the hand, aside the clip and that they could have rounded the inside handle slab edges a bit more, they felt pretty sharp. Opening was smooth, but not in the same league as a CRK. The CRK is much more "hydraulic" than the 761 was and the lockup feels/sounds more solid. You really need to experience the CRKs to understand those descriptors I think. The 761 blade is not "overbuilt" and it should be a really good slicer.
The 761 wins hands down when it comes to blade steel, M390 at RC 60-62 is going to crush S35VN RC 58-59. S35VN isn't a "bad" steel but I suspect it's only popular because it's easy to grind and heat treat, i.e. cheap to use. I'd like to think with so many production knives using high end steels that mid-tech's would start upping their game but most haven't. I believe this reflects the trend that knives are becoming more of a fashion/status statement and less about cutting performance, like watches.
I had four complaints on the 761's I handled YMMV.
1) Tip down only. Having the clip on the pivot end of the knife makes for a uncomfortable grip when using the knife. If you're a tip down guy, then the CRK 25 is equally bad. The 761 isn't horrible here because of the tall handle and the fact the clip is pretty wide and the edges are rounded since it's machined.
2) The detent/blade retention was very weak. Old BM 760 had the same issue. The all CRK knives I've seen have very good blade retention and solid detents. If I have to carry a weak detent knife I want the blade spine against the pocket seam. With the 761 you'd have to carry it in your left pocket to do that, and with only one thumb stud, opening left handed is much like a monkey having relations with a football.
3) Thumb stud on only one side of the blade, just no excuse for this.
4) asymmetrical blade stop pin. The old BM 760 is the only other BM I've seen use this. CRK is no better the 25 has an asymmetrical stop pin as well. In both cases neither have proven a common issue, but I'd prefer a blade stop that if it rotates/moves doesn't create an unsafe or unusable knife.
Price is personal, I could make the case that there are other production knives with Ti handles, and high end blade steel that are significantly cheaper than the 761. However, if materials and blade steel are the criteria to value then the 25 is even more over priced offering only a 58-59 RC S35VN blade.
If it had dual thumb studs, offered tip up carry, and had better blade retention when closed I'd own a 761. Then again if the old 760 offered those things I'd still own it as well
